General Discussion \  Hey new member from Mboro TN With a question about the weber
General Discussion
views 869
replies 2
drifter615   +1y
I recently bought a b2200 with a Weber 32/36 and i cant pass emissions it does have all the desmoging done but i'm running rich anyone got a answer on what i can do as far as i have found out its from stock FPR running high pressure but the truck doesn't seem to bog down like you would think. Bur it running rich by the emissions standanders. i have found a cheap FPR that should put out a lower pressure but do i need to bypass the old fpr? plz help running on a temp tag and need this truck to get to work
Cusser   +1y
A 5-speed truck with mechanical fuel pump shouldn't need a FPR with this Weber (I don't use FPR on mine, 9 years now).
If your pressure is high though, lower it. If adjusting the weber screws "in" don't do it, maybe smaller idle/main jets.
xxchromeghostxx   +1y
What part of TN are you in to have emissions? I was from NE TN and had no testing.
