General Discussion \  Thanks for the add!
Thanks for the add!
General Discussion
views 802
replies 1
following 2
turbo1344   +1y
Thanks for the add. I recently acquired a 1989 Mazda B2000 and want to turbo the 2.0. any suggestions and help would be greatly appreciated.
low_life77   +1y
Welcome to the site! We need pics!!! And to give some advice I would first start by asking is it carbed or EFI? It is fairly easy to turbo these engines as they came from the factory this way in certain models. You can do it the cheap and easy way by using the factory turbo set up from a Probe or MX6 the turbo manifolds will bolt right up to our heads, use the stock turbo, combine the wire harness from a probe/mx6 to yours, and run the factory ecu from the probe/mx6. That is if your engine is fuel injected. You will also have to tap into the block for oil lines. If not then you can run a blow through set up. That I don't know much about though being everything I have boosted has been EFI. But you can always search the modification threads under engines and see if you can find what you are looking for. A lot of guys boost the stock engines since they can handle it very well. Or you can always go after market. More money but in the long run more power. Iv'e seen guys do mild builds with some head work and aftermarket turbo setup and make 300-400hp easy with these tiny engines.
