battery tray corrosion
cenglish11
I have a clean battery and clean terminals with no corrosion, however the battery tray keeps corroding . Any input on this would be appreciated.
Cusser's avatar
Cusser
Is your battery securely mounted with a top bracket so that it cannot shift around?
Could possibly your battery be cracked?
Could possibly your battery be overfilled?
Could possibly your alternator/regulator be putting out too much voltage?
I'd check those four.
mazdatweaker_2
You might have corrosion built up inside one or the other of the cables. I'm thinking that maybe where the ground cable connects to the body that you might need to clean that point.
missed.a.leter's avatar
missed.a.leter
After trouble shooting and fixing any problems go to the autoparts store and get a plastic tray for the battery. It just sits on top of the stock steel tray. Plastic dosent corrode from battery acid. Good luck!
cenglish11
Thank you all sooooooo much for the info.
kewldan's avatar
kewldan
Unbolt the tray, scrape it clean with a wire brush, use rust dissolver if need, spray rustoleum primer and repaint, that's what I did.. I can send you pics.
cenglish11
Hey Thanks For the reply . I actually did all that , the only thing I did different was apply dupli color bed coating to the tray and to the fender well area , turned out nice , so for so good.
