can anyone suggest one that can be run offa 110 that will be able to do body mods an patches.. eg. my rockers are fucked!
lol
impulse
miller 135
Im either getting one of those or if I get 220 put in the garage im getting the 175.
midnightmike
im using a lincon its not big but it does up to a 1/4 inch plate
Ive used a lincoln 3200 HD on my truck its pretty powerful for a 110 mig, it can weld up to 5/16 but I've found when welding 1/4 tubing it works alot better if I cut a grove into the joint to help it penetrate better and the weld is more flush with the surface then sitting on top. I'm saving up for a 220
jsnpdy22
I have a millermatic 210 and it works great. Ive used it to shave my ant,doors,and emblem holes.I use .030 wire for body work and .045 for my suspension work.
N
nateid15
miller 135... great little welder for the $$ (around $350)
dont buy a cart for it... make one... ul learn how to weld too :p
U got welding equipment/knolage... really dont want to sound like an idiot if you allready know what your doing...
~Nate
2fine89
Lincoln sp100 it's the best 110 mig that I have come across. I think it's replacement is the sp 135 now.
