General Discussion \  stock tire size and 16inch tire size
General Discussion
views 2795
replies 10
following 6
mark   +1y
is the factory 14inch tire 205/70 or 205/75, i forgot which one it is
also, what size tires do you guys run with your 16s, pls post pics too
2fine89   +1y
Mine were 195-75-14's stock on mine. which is close to 25x8x14. IF I go 16's I'll prolly use 225-50-16's close to 25x9x16.
disciple   +1y
i run a set of 225 /50 /16 they give me a bit of smoother ride with my static drop another option would be 205 /40/16 over all diameter is smaller truck will sit lower but the ride will be rough, sorry no photos yet still working on that.
mark   +1y
k thks, the reason i was asking about 16s is that im getting a cheap set because 2 of my 14s are not true anymore and it jirates the truck
the wheels already has some big tires on it, i think 225-65, but they stick out pass the side of the wheel, so i can't tuck them in the back.....so i was thinking maybe 205-50s would work
rollinslow   +1y
Heres mine with 205/55/16's. They measure 24.9 inches tall.
mark   +1y
k thks
looking at them from the front of the truck, would those tires tuck out back with yer wheels?
tskb2200   +1y
yea i have the 205/40r16 on mine not the best ride but it could be worse. think when i buy new tires i'm gonna go with a 205/45 though little bit better ride
mark   +1y
yea i think ima get 205/50's or 205/55's....the 50s are the same diameter as my tires now...a 55 would be closer to stock..so i dunno, might get a 55
89b2200   +1y
I have 225/55/16 and they stick out a little so you can't tuck them in when you drop.
mark   +1y
yea, have to get a 205
