Navi Wheels 6LUG 18's will they fit ?
bagged89mazda
when i had my truck bagged it was set up to ride on a set of 18's every one is using caddies or z71's these are 6 lug but will they fit ? what modifications to the wheel itsself has to be done to work? Cause im thinking of lookin into a set here in the next month .
grantkustoms's avatar
grantkustoms
I saw a set on a mazda this last weekend at drop zone, so there is a way
mark
any GM fullsize 6lug will bolt up, just need the center hole to be bored to the mazda's hub size, 93mm
Ford 6lugs are off by couple millimeters, it will not be centered, you can get away with boring the center hole and centering it that way, but once you start tightening the lug nuts, the studs will bend, the studs will not be centered on the hole so the buldge on the nuts will force it to be therefore bending the studs
people get away with bolting on the navis, but ppl also get away with hack jobs
but if you're really set on the navis, get the wheel redrilled to 6x5.5 instead of 6x5.75 or whatever Ford 6lug is, otherwise, get a GM wheel
Post was last edited on Aug 01, 2005 10:49. Edited 1 time.
bagged89mazda
if they require cutting the tabs off the hubs then i don't want em . what if down the road i wanta put another rim on there or put the factories on again . if i grind the hub i can't put them back on .
thetornado's avatar
thetornado
u could get them bored out bigger like the Z71's. not sure if that what needs done to them though....
mark
thats why i was saying to bore out the middle of the wheels to 93mm, 93mm is the mazda hub bore, not grind your tabs down
sickspmini
just take them to the machine shop and have the lug pattern redrilled
thats what a guy in my club did to make them fit the nissan
chilnviln's avatar
chilnviln
the navigators are 6 on 135mm while gms, mazda, nissan, etc. are 6 on 139
mark
^^ what he said
thats why you cant bolt them straight up, plus the hub bore size is diff.
