Aftermarket gauges?
saggiosrp@comcast.net's avatar
Aftermarket gauges?
saggio's avatar
saggio
Who has aftermarket gauges installed in their Mazda?
Oil Pressure
Water Temp
Anything? Have pictures?
HERE ARE MY NEW GAUGES INSTALLED!!!
I need to clean the vents up, this dash consel was in a junk yard 8 hours ago! I F'ed up my original consel so I had to go to a junk yard and pull this one out of a beater truck.
Enjoy!
One pic with the Tach I installed last year...
Post was last edited on Mar 31, 2006 04:30. Edited 2 times.
midnightmike's avatar
midnightmike
ive got:
oil pressure, and voltage, and the console where the radio used to be is all my air pressure gauges
rutter0907
i've got aftermarket gauges by dakota digital.
limequat's avatar
limequat
No heat?
I have an Autometer water temp gauge screwed to the side of my cluster. Never figured how to make a chevy sender work with the Mazda gauge. Shouldn't have been hard...but it was
midnightmike
nope no heat,although i am in canada i dont need heat all the time
saggio's avatar
saggio
Where did you tap in for water temp?
limequat's avatar
limequat
I soldered a lead off of the back of the cluster.
saggio's avatar
saggio
So you used the factory sensor? I tried tapping into that wire and my gauge was freaking out.
(EDIT: I Updated the first post with pics of my newly installed gauges)
limequat's avatar
limequat
You know, now that you mention it, I may have cut the wire going into the cluster. That would make more sense.
My problem WAS the factory sensor. Mazda uses this crazy M5.5 threaded sensor made out of what appears to be used bubble gum. You can over torque the damn thing with your fingers. And that torque is way less than the torque required to get the thing to seal.
IIRC, I have a GM Sender running through the factory wiring - then to an Autometer gauge. I hate the way the autometer looks, hanging off my cluster, but I won't live without a gauge that actually has numbers on it.
Anyway, I largely digress. You can't leave both the aftermarket and factory gauge hooked up. Their impedences will add, and your readings will be off. Beyond that, I think the Mazda sender has the wrong scaling anyhow.
lukeinva
I got the same steering wheel!
