dragging question
loweredintensions@excite.com's avatar
dragging question
projekt94 (david)'s avatar
projekt94 (david)
hey guys got a lil question to ask. i recently welded blocks to my frame under the doors so i can drag the mid front. i used to drag the ass end of my truck. now that i have a fiberglass bed i cant do it no more. i was wondering if i drag the front will the sparks be too hot for my air line? would it melt through? ive drug a hole in the line once dragging the back end. i have wire tied loose line to the frame, would it be ok there? is there some kind of cover material, like wire loom or something that i can put over the line? any suggestions would be appreciated. thanx!
slammed83mazda's avatar
slammed83mazda
depends on how you drag? do you go balls out or do a lil cat drag here and there?
projekt94 (david)
i go balls!
midnightmike's avatar
midnightmike
i welded blocks to the front crossmember and i hammer the bitch all the time, and i havent had a problem yet
slammed83mazda
same here but im running hydraulic line so i would never have to worry about this
projekt94 (david)
so then my line would be ok?
slammed83mazda
should be
projekt94 (david)
cool! thanx man for your help
mullet
also depends how u ran your air line.. and what type of metal your dragging. If you ran the line right behind the block to be sprayed down.. then i would worry. If i was dragging titanium.. then i would worry.. but if its just normal steel blocks and the air lines are directly behind it.. then i say drag it!
Mike
projekt94 (david)
its just pieces of scrap metal i found around the shop. duz throw a shower of sparks!
