welding
welding
lucky13
Hey guys just wondering, i have a hobart 125 with flux core, i am soon to upgrade it to gas. will this be good for all my mini truckin needs because im going to do all the welding, ive been welding for 3 years and know how to, but just wanted to make sure my welder is up to it?
btw what welders are you guys using?
roach25681
Id leave it as fluxcore if youre going to be doing framework. Gas for body work.
lucky13
so flux penitrates more? and will 125 amps do the job?
slammed83mazda's avatar
slammed83mazda
gas can be used for frames, and yes its better ur welds will look alot cleaner and such
phatkix's avatar
phatkix
my flux core welds are very clean when scratch brushed...........gas will make less spatter for sure.
roach25681
Yea flux core penetrates much better. And yes 125 amps is enough. I did all my rear framework with an 88 amp flux core. I can penetrate 1/4" easily with that.
impulse's avatar
impulse
i'd definatly go gas.
robbie
a good rule of thumb when welding is you need 1 amp for every thousandth of an inch and then add a 50 amp buffer so you aren't pushing the welder to its limits. 1/4" of an inch is .250 so if you were going to weld it by the "book" a 250 amp machine would be required then add another 50 so its not at its peak. You can do frame work with a 135amp machine though you are just going to need to spend more time prepping your metal. Chamfer all your edges, run a stringer bead then do your cap bead over that.
roach25681
If you know what you are doing, like you say you do, then you will be fine. Of course you'd be better off with a different machine, but if you dont have the extra cash to go buy another, then it is possible to do it just as good with the machine you have now. Just make sure you take your time, go SLOW, burn the weld in real good, and prep your metal good.
mark
thats true, but when you have a hobart 125, you're better off using flux core welding on a frame rather than using the gas. the gas will just hinder you. yes your welds might look clean, but that's just on top.
