nytrdr24
TRY A 626 CABLE, IT MIGHT BE SHORTER, TRY A LITTLE CREATIVE ROUTING TO TAKE UP SOME OF THE CABLE SLACK....RUN IT DOWN THE SIDE OF THE ENGINE WITH THE SPARKPLUG WIRES, YOU COULD MAKE SOME STRAPS THAT BOLT TO THE PLUG WIRE SEPERATORS, THEN ACROSS THE FRONT OF THE ENGINE TO THE CARB. AS FAR AS THE LINKAGE, YOU MAY HAVE TO FAB UP SOMETHING....IF ALL YOU HAVE IS A HEADER, THE 38 MIGHT WOULD BE A LITTLE OVER KILL.....UNLESS YOU INTEND ON DOING SOME OTHER MODS TO YOUR MOTOR.... IF WORST COMES TO WORST, CHECK AROUND WHERE YOU LIVE THERE'S BOUND TO BE SOMEONE THAT COULD MAKE YOU A CUSTOM LENGTH CABLE.....PROBABLY COST @ $100.
GOOD LUCK!
