WHO'S TRUCK IS THIS??
12 following
pocket_rocket05@hotmail.com's avatar
devb22's avatar
devb22
Anyone know who's truck this is, and how I can get in contact with him/her???
Any info would be appreciated!
Dev
devb22's avatar
devb22
Nevermind, I found him!
Thanks!
Dev
southernrazed
hey am i gonna have that much camber with stock controal arms..flipped ball joints..and cut uppers?..obviously i can see i have camber now but with no fenders it dosent look like as much as in the pic. anyways i hope i have that much camber..my rear cambers a little but its realy not too pronounced....oh yea..i got my 4X4 bed today..coupple dents..but minimal rust
mullet
Actually flipping the ball joints corrects the camber more. For the most negitive camber just trim the uppers and lay it out.
Mike
devb22's avatar
devb22
^^ Thats some good info! ^^
Dev
bagged2600's avatar
bagged2600
Well,the black truck is pimp.. I like the grill.
mark
Yep. You actually have less camber when you flip the lower balljoint and leave the upper stock. This is because your lower arm is at a "lower" position through it's range of travel, thus kicking the lower part of the wheel IN, which gives you less camber angle. But if you flip both lower and upper, you pretty much get the same camber as stock. This is because you're moving the upper arm and lower arm "down" the same distance. We're talking half a degree of camber here, so I really wouldn't worry about it. If you want less camber, pie cut your upper arm.
What it messes with is the instant center in the front. Mazda set this from the factory so that the upper arm angle, lower arm angle, and tie rod end angle meet in a single point. Now that the lower arm angle has been tampered with, it is not the same. What I've noticed from personal experience is increase in bumpsteer, but it's still pretty stable to not be worried about.
To me it's worth flipping your balljoints for that extra drop if needed. Just make sure you use new bolts and watch the arm just in case it begins to bend at the tip because of the removed material.
madmazda
Its Sweet, Is this dude on this site?? Where's he from??
speedster93b's avatar
speedster93b
when we're talking about trimming the upper control arms, what is being trimmed? and from where?
and pie cutting the upper arm? where would one pie cut it? why?
fanninator's avatar
fanninator
dayum, what kinda front bumper is that?? -bf
