nitrous
plyduster426@hotmail.com's avatar
nitrous
zakkwylde's avatar
zakkwylde
lookin for some info on nitrous systems. anyone know if the make a plate system for our trucks?? or is my only option a fogger?
gravity5's avatar
gravity5
No Plate for the mazda as far as I know...although you could make a plate. But the fogger is a good system, even better an individual runner multiport fogger setup.
lowblownranger
well like someone else said on bscene said nitrous is like a hot chick with an STD you wanna hit it but you know what will happen if you do...... jk in the right hands with the right brain.... nitrous can be a great power adder... as long as your sensible its good..... its also a very good diagnostic tool when applied to your motor if you end up walking home your motor couldnt handle it and it was in bad shape...... about your question..... NO PLATE anywhere that i found at least..... do a fogger kit!!!!! and hold on !!! keep us posted
baggedb22
if your gonna run nitrous on a stock 2.0 or 2.2 atleast do a compression test first and start out with a small shot, i'd also run some type of wet system im not to into the dry setups i no zex makes a kit with a brain box that only adds as much nitrous as it feels the motor can handle to try and make it more care free....
nytrdr24's avatar
nytrdr24
like my man bagged said, i would go with a wet setup, & some kind of controller & deffinately check out the motor first, if you serious about it, it wouldn't be a bad idea to invest in a copper head gasket & a set of head studs....but that is just my 0.02.....
zakkwylde's avatar
zakkwylde
thats what the plan was i am building the motor i wont ever just shoot a worn out stock motor. ...unless i am really bore. i am just getting my partslist together. i was thinking about a 5 wet shot with the jets taped into the intake right below the carb.
