MPV, Pathfinder Rear Disc Brakes
limequat avatar
limequat
Anybody have an MPV they could take a look at? In 1994 at least, they came with rear disc brakes and a solid rear axle. I have to think the calipers would be a near bolt-in. Also Pathfinders have near identical specs to the MPV, but with the correct bolt pattern.
v8mazda4ever avatar
v8mazda4ever
I put the 1994 nissan rear end out of a pathfinder in my 1991 mazda reg cab the only thing is you have to run 16 inch or bigger rims as the stock mazdas dont fit just like if you run drop spindles on the front the tie rod ends will rub
mazdawg(mikey) avatar
mazdawg(mikey)
the mpv rearend is like 2"-4" wider than a regular mazda rearend. i cant remember exactly how wide but i had a friend with a spare mpv. he snatched the rearend without measuring it. had it almost completely installed in his truck when he found out it was too wide.
limequat avatar
limequat
Actually, the MPV rear is as exactly as wide a B2600 4x4 rear: 1540 mm.
The 4x2 rear is 1410 mm.
