Page 1 of 4
General Discussion \  List Your Mods
List Your Mods
General Discussion
views 4279
replies 30
following 20
lowblownranger   +1y
well im really bored so i figured id come up with somethign to write about lets list our mods to see what all every one has done
1. b2600i hood
2. shaved door handles
3. flipped ball joints
4. shaved tailgate handle
5. shaved gas door
6. fiberglassed dash peices (baggedb22's)
7. weber carb
8. taylor master disconect switch
9. c notched
10. bridged
11. reindexed torsion bars
12.removed wheel wells
13. tinted windows
14. solid rear window
15. bed mounted battery
16. bed mounted gas tank
17. flat black w/ chrome center cap factory wheels
18. redded out taillights
19. shaved b pillar vent holes
20. rear frame cleaned off all brakets except bed and suspension
21. alpine cd player
22. NO MORE 6 X 9 ran into them with the seat
23. kove 10'' making custom box
24. led dash lights
25. 3 inch blocks
26. mono leafed
27. cranked torsion bars
28. removed rear bumper
29. pollution control removed
30. all bump stops and mounts removed
31. shaved emblems
u
Post was last edited on Mar 09, 2007 02:03. This post has been edited 3 times.
gravity5   +1y
1.)shaved door handles with custom hidden handles
2.) shaved tailgate handle
3.) frenched and angled plate box
4.) Rollpan
5.) Bags
6.) Bodydropped
7.) Led's in rollpan
8.) custom paint
9.) smoothed upper bodyline
10.) smoothed bedrails of both body line and stake pockets
11.) shaved thrid brake light
12.) custom one off hood
13.) clear front corners
14.) LED dash lights
15.) 4 link
16.) 3 custom home made airtanks
17.) home made ceramic coated intake
18.) high comp heads
19.) headman headers
20.) flowmaster custom bent exhaust
21.) Full stereo ( 6.5 inch seperates, 2 12 inch subs, 2 amps )
22.) Billet steering wheel
23.) painted door panels
24.) tweeded dash and interior panels
25.) custom switch panel
26.) clifford alarm
27.) scuba tank in bed
28.) tubbed and capped bed
29.) tubbed under hood
30.) shaved emblems
31.) custom EDC and mount
32.) relocated battery
33.) SHOULD I KEEP GOING.....hahahah
soon to have a small block, new rear end, 22's balh blah blah...as soon as I get a break from the customers I will cut her back up.
crazymikey   +1y
you realize this thread will either die shortly,or will take off and become 50 million pages long...
...but since it's 2am and I've got nothing better to do...
1.Primered
2.Toxic drop shocks
3.Belltech 3" blocks
4.Monoleafed
5.Cranked torsions
6.Flipped ball joints
7.Set of stock 14" chromies,and a set of Pathys
8.H4 headlights
9.Red-out tails with chrome trim
10.Clear front signals/corners
11.Chrome front bumper
12.Chrome grille
13.Removed rear bumper
14.Bubble hood
15.Stamped tail gate
16.Drop in bedliner
17.Tonneau Masters soft clamp on tonneau cover
18.Tinted windows
19.Smaller stock mirrors (replaced elephant ears)
20a.Interior swap from burgundy to grey
b)Buckets,with removed headrests
c)LX door panels
d)centre console
21.Grant Challenger 860 steering wheel
22.Sony CDXF7710 head unit
23. Four 4" Pioneer speakers (2 in dash,2 in cab corners)
24.Two Pioneer 3-way 6x9s in boxes behind LH seat/console
25. 10" Max Pentivent sub in sealed box behind RH seat
26.Kenwood KAC6402 4 channel 400w amp
27.Rebuilt engine
a)bored out .030,oversized pistons,all new internals
b)Ported and polished head
c)Accel high flow air filter
d)NGK plugs and wires
e)new clutch (oem)
f)new rad
g)Dynomax muffler
h)Magnaflow high flow cat
i)2.25" piping,exiting under bed infront of LR wheel,custom made dual slash cut tips
To do ASAP:
1)Tires for Pathfinder rims
2)Grant rollpan
3)Bodywork / respray
4)DVD system
5)Cut off front bumpstops
laydoutb26   +1y
bored...
here goes...
1.clear corners and signals (sold)
2.chrome front bumper
3.chrome grill
4.powdercoated engine parts
5.cold air intake
6.kick pod enclosures
7.cd player
8.tinted windows
9.bed liner
10.roll pan
11.shaved emblems
12.chrome door handles
13.chrome tailgate handle
14.cranked torsion bars
15.flipped balljoints
16.removed bumpstops
17.mono leaf
18.2" blocks
19.air shocks
20.chrome 14" mazda wheels
21.removed backseat
22.rewired signals to corner lights
23.tweeters in a pillars
24.stock buckets sans headrests
25.chrome taillight bezels
soon to have LED signals
soon to be shaven
nytrdr24   +1y
i can't say done on some of it, but inprogress is more like it.....
body:
1. 4*4 bed
2. 4*4 fenders
3. 4*4 end caps
4. chrome bumper
5. new valance
6. chrome grille
7. clear corners & turn sigs
8. carbon fiber altezza tails
9. new rad support
10. new passenger door
11. new passenger cab corner
12. stillen valance spoiler
to do on body:
1. custom roll pan & diffusers
2. flush mount tonneau
3. shaven gas filler door
4. partially shaven cowl
5. grant kustoms corner pillars
6. shaven doors & t/g handle relocated
7. shaven drip rails
8. shaven antenna
9. smoothed & filled body lines
10. billet rear view mirrors
11. reshaping hood (add cowl) or c/f hood
suspension & chassis:
1. djm 3" drop cont. arms
2. re-indexed t-bars
3. toxic shocks on all 4 corners
4. 3" bell tech drop leaf sp.
5. bell tech frt sway bar
6. bell tech rear sway bar
7. relocated rear shocks
8. new ball joints
9. poly bushings
10. new steering linkage
11. removed front b-stops brackets
suspension & chassis to do, or may do?
1. 84-85 rx-7 gsl-se rear axle conversion (lsd & 10" disc brakes)
2. coil overs in rear
3. coil overs in front or air shocks for some adjustability (height wise)
4. adjustable upper control arms
braking:
1. hawk brake pads
2. goodridge stainless lines
3. slotted / x-drilled cryo treated frt rotors
to do braking:
1. rx-7 rear disc
2. slotted cryo treated rear rotors
3. remove old e-brakes, install line lock
engine:
1. full cryo treat
2. bore increase from 86 to 87mm
3. forged wiseco 10.5:1 pistons & rings
4. are head & main studs
5. 1+ mm larger ferrera intake & exhaust valves
6. bronze valve guides
7. hi rpm valve springs & retainers
8. manual rocker arm conversion
9. 262 duration cam w/ .420 valve lift
10. rpmz performance dizzy
11. accel 300+ ignition
12. taylor 8+ mm wires
13. ngk plugs
14. centerforce dual friction clutch & t.o bearing
15. 2-row automatic tranny radiator
16. dual 10" elect. fans removed stock unit
17. hi-flow oil pump
18. 180 deg. thermostat
19. 9.5 lb fidnza flywheel
20. relocated dual battrery setup (optima)
21. pacesetter armor coated header
22. pacesetter hi-flow cat
23. magna flow muffler
24. aeromotive fuel pump, regulator, & filters
25. new fuel line, hard pipe & braided, an fittings
26. 16 gal. jaz fuel cell mounted under rear of bed
27. dual side draft weber dcoe's
28. custom intake manifold
a bunch more, will finish later....maybe.....time to go to the hizzy for a nap!
Post was last edited on Mar 10, 2007 04:03. This post has been edited 3 times.
hocbj23   +1y
Nytrd forgot his hi speed gas cap.Lol.2600i hood,4x4 grille ,polished and ported head,street cam,stiffer springs with aluminum retainers,aluminum crank pulley,13"Flexalite electric fan,reworked A/T with higher shift points,Accel coil,Weber on polished and ported intake,H2O injection (homemade),Flowmaster 40,Magnaflow cat,slotted rotors,ceramic pads,stainless brake lines,Tokico R/t shocks,Belltech rear sway bar,poly bushings in front sway and end links,clears at all 4 corners,Micro suede interior,full gauges,Sony xPlod with Boston acoustic speakers,el interior lighting,custom sill plates,unicolor B pillars AND a hi speed gas cap.BJ
limequat   +1y
There are few parts on the truck that are stock
Drivetrain:
Chevy 4.3 Vortec Engine
T5 Trans out of a firebird
S10 Shifter
Custom Driveshaft
4x4 rear end housing and axles
8" LSD from TII RX7
4x4 Wheels
Body:
3" body lift
Chrome Grill
4x4 fenders and end caps
rear bumper delete
shaved emblems/molding
rattlecan flat black
Interior/Audio
MP3 player in dash
6.5" Speakers in stock rear location (extended cab)
Keyless Entry
RX7 Steering Wheel
In Progress
4x4 front frame section (done)
Front Coilover conversion
4x4 conversion
Tacoma R150 Trans swap
4.1 Ratio change (rear done)
twistedsmily   +1y
ok im in
1. piant white with blue medalflac
2. shaved handels .dice opener onthe drivers side (cut up old antena top off with dice)
3. no toursions ,bumpstops
4. mono three" block, no bumpstops
5. cut open breather
6. take a little trip sticker on the back window
7. T 100 wheels with 205\50s
8.two tens bahind seat / pioneer cd player
9.2600i hood stamped mazda tail gate
devb22   +1y
Is that in English????
Dev
lowblownranger   +1y
i just realized how a lot of that was spelled funky lol kinda threw me for a loop when i read it
