General Discussion \  need trad. bodydrop help really bad ASAP
General Discussion
views 724
replies 1
following 2
86mazyota   +1y
i have completed the cab 2.5 inch bodydrop to the rockers now i am trouble with the radiator support. We cut ii off at the frame and moved it down 2.5 inches and now the brackets for the bars that bolt to my lower control arms is pushing the truck up in the front. The question is do i need these and if so ho much do you lower the front radiator support when welding it back on the frame. lmk ASAP as this is all thats holding me up.
my email has changed to
speedster93b   +1y
ok, the bars that mount to your control arms are called strut rods. they are pretty necessary - they hold your control arm from moving fore and aft. what you can do is notch your core support out for the frame rails to move upward. you might run into problems with your lower radiator hose on the crossmember though. you can notch that crossmember.
