what size.....
nytrdr24@yahoo.com's avatar
what size.....
nytrdr24's avatar
nytrdr24
for those that are rollin on 18's, what size tire are you running, and on what width rim....?
nytrdr24's avatar
nytrdr24
bump, no one's runnin 18's?
mazda23
i have another question(not tryin to jack thread but on the same topic) whats the widest you can run with 18s and stock 2wd fenders?? and i have the same tire question too
rawdawg
my buddy was running 215/35/18 on a 18x8 rim on his mazda. i thought it looked pretty good.
mazda23
with stock fenders?? and was it bagged
nytrdr24's avatar
nytrdr24
interesting, i'd have thought that might be a little narrow on an 8" wide rim.....i think i'm gonna get some falken ziex-512's like i have on my centerlines, i have 225/50-16's on them & it is a 7.5" rim, and the tread cross section is as wide as the rim is. so i'm thinking of either a 225 or 235/40-18 cause i want the tread cross section as wide as the rim or close to it.
speedster93b's avatar
speedster93b
for a while i was running 205/60/15's that were the roughly the same size as a 215/35/18, and they tucked fine... its all about the offset/backspace.
clarification: they tucked fine before the body drop!!! now i have a cunt hair of clearance between the tire and fender at ride height.
i know that doesn't answer any questions but whatever...
nytrdr24's avatar
nytrdr24
well, the whole reason i'm asking is, as ya'll know i bought an
84-85 rx-7 gsl-se rear end, it has lsd, and 10" rear disc brakes.
the lug pattern is 4 x 4.5. currently i still have the stock 6 lug pattern and a set of 16 x 7.5" centerline sunray 6's, they have a 4.25 back space, which is @ a 12mm offset. they come just slightly less than flush with the 4wd sheetmetal i have. the axles & lsd diff carrier are interchangable between the axle housings.....and are both are the same width from wms to wms, i bought the rx's rear so i could have the lsd, and rear disc brakes, & in order to use the brakes, i'm gonna have to use the rx's housing. i wanted to keep the 6 lug pattern, cause i already have wheels, but there inlies the problem.
the 6 lug pattern is too big to run with the gsl-se's rotors.....so i'm gonna have to swap to a 5 x 4.5 lug pattern, and redrill the shafts, rotors, and hubs, so the ole centerlines aren't gonna work anymore
keep in mind i'm not bagged, or bodydropp'd nor gonna be (yes i hear the crowd booing) just gonna be static dropped as low as i can & still maintain a decent ride, although i may swap out the leafs in the rear for a wishbone link setup in the future. with the 4wd sheet metal i can run a wide width wheel 7" or 8", & won't sling debris up on my paint when i manage to get that far.
well, i found a set of 18's @ a good price to run with the new lug pattern, motegi dp10's glossy black painted center, machined lip, 18 x 8, 5 x 4.5, with a 30mm offset (should come about the same distance from the edge of the fender as the centerlines, maybe tuck a little more than them). so i was just wondering what size tires peeps were running with what width 18's.
here's a couple pics of the wheels
rawdawg
those are some real nice looking rims, should look killer on the truck. the tires that my buddy had were falkin's also, the tire had a little bit of a stretch on look and didn't stick out past the edge of the rim. this was needed to help with some tucking clearance issues.
devb22's avatar
devb22
I'm running 18s on a 225/35ZR18 tire...
I believe the width is 8.5"
Dev
