General Discussion \  navigator rims
navigator rims
General Discussion
views 823
replies 6
following 5
solow93 (ryan)   +1y
I just got a set of navigator rims there 18's I was woundering what size ruber you guys are running on them my truck will be bagged when I put these on. So any help would be great
droppedmitsu   +1y
I would put on like a 215/35 or 215/40 or somewhere around there
sierrax   +1y
How wide its the rim?
joshbrennan   +1y
I'm pretty sure the navigators are 18x7.5.
Regardless of what tire you put on them, make sure you redrill the wheels or your hubs/axles as the bolt pattern on the navigators is 6x135 where as the mazdas are 6x139.7.
lowblownranger   +1y
i didnt think they were the same lug spacing i had the idea before and found out i wouldnt be able to use the wheels un less i adapted them
sierrax   +1y
235/35/18 or even a 245/35/18. Those tires run a height of 24 1/2" to 24 3/4" high which is close to stock and most 16 and 17 tires that are used to lay out.
Check the link below. It list all of the tire sizes and heights. See what fits.
solow93 (ryan)   +1y
Ok Thanks guys that helps
