need locations to un-bolt bed
blastation
Hi everyone well i am finally going to start my 87 mazda, and need to know how to remove the bed, can someone have a diagram of where all the points are and how hard is it to remove if i am by myself. Also can some post pics of all the mounting points thanks everyon. Another question i got cadi rims will thos tuck under the regular fender and bed or will i need to get different fender and bed
mazda23
on the regular cab theres 8 bolts. 2 infront and 2 behind the tire on each side. You just unbolt those and your fuel filler and the bracket that holds it there. I did it by myself but i had a hoist and hooks inside my bed which mad it easier. Hope this helps. And anyone feel free to correct me
elbine69's avatar
elbine69
yup theres 8 bolts and dont forget to pull the taillight wiring harnesses out of the bed before you try to pull the bed.
blastation
thanks for the fast response guys, will have to go check it out right now
V
v8mazda4ever
No you have it right just make sure you have a set of torches handy as they might need to be heated up before they will come out.
nytrdr24's avatar
nytrdr24
just for reference, there's a pic in the tech gallery of a frame, you can see the body mount locations on it....
blastation
already save it and printed it out thanks NYTRDR24. hopefully i wont have to use a torch
nytrdr24's avatar
nytrdr24
before ya break out the torch, try some pb's penetrating blaster, sorta like wd-40, but waaaaay better at breaking seized up stuff loose!
dropped90(justin)'s avatar
dropped90(justin)
this may be the easiest part but i always forget the easiest things but dont forget to unplug those tailights and tag light. also your gas filler.
