General Discussion \  rear discs on stock rearend.
General Discussion
views 1198
replies 11
following 7
low mazda   +1y
ok, i saw someone had this in the toyota section over on SSM, and got curious. Would this be possible on a mazda also? Maybe use some pathfinder rotors and calipers, but hand fab some kind of bracketry
fanninator   +1y
i donno. it is hard to hold the 2700lb and 90hp back tho. -bf
low mazda   +1y
i don't care about holding power, that's why the body sits on the ground.. I want looks..
v8mazda4ever   +1y
I got the whole rear end out of a nissan 1994 pathfinder and it works perfectly
elbine69   +1y
Ive been wondering about this for some time also. Seems like it would work if you made some brackets for the calipers and welded them on the axle.
nytrdr24   +1y
if you wanted to swap to a 4wd 90-97 yota rear end (i believe that is the correct years, would have to double check tho, they are the same width from wms to wms, and you get a couple different gearing options), you can get a disc conversion for it from downey off road.....
also, i've heard of using late model chevy rotors, and calipers off of a montecarlo.....someone else suggested using a pathy rearend that already came w/ disc.....other than that, if you plan on going to a 5-lug setup, you could do what i've started on, 84-85 rx-7 gsl-se rearend, they are limited slip, 4.07:1 gear ratio, and come with disc already which is nice, but you'll have to cut off all of the existing bracketry (as those rx's were a link type w/ coil springs in the rear), and weld some new on bracketry, also it is a 4 x 4.5" lug pattern, so you will have to get the disc & axles redrilled (won't work for 6-lug application as the disc are too small in the mounting surface area) you can reuse the trucks e-brake cable on these calipers, but will need to have the cable shortened a little, and a button crimped on the end.
this topic has popped up every now & then, and think limequat had done some research into the pathy rear, and maybe another as a source for a rear disc setup......
pont   +1y
you can use the front rotors off a 4x4 Chevy truck that is 6 lug you will have to bore out the center hole just like the rims. then get some rear calipers off a old caddy that has a cable Ebreak and make brackets for them to mount to the rearend.
low mazda   +1y
well, when your body is on the ground, you don't need an e-brake. As for all the 4 and 5 lug stuff, that don't help me out.
As for the whole rear end of the pathfinder, wouldn't do me any good, cuz my fourlink is already welded in place,
so I am going to try and use the newer 6 lug stuff from a chevy and some caddy rear calipers..
do you know what years to get this stuff?
and as for boring out the holes, I wouldn't have to. The tabs and stuff have already been cut off my axles on both sides. Cuz i ddin't want to pay someone to do something that ddin't really need to be done when I had my navigator wheels.
elbine69   +1y
If your gonna do this please take some pics and tell us how it works out.
killerb   +1y
89/90 Isuzu Rodeo rear discs and calipers, and the calipers have e-brake cables. Done it to my truck an had to make mounting brakets and still in the process of trying to figure out how to get the e-brake cables to hold.
