hex0rz
Eh, I would do this in the seller feedback and all, but I have more to say than just giving dev some props! Hey man, thanks for the MSD blaster ignition!
Well worth the $100 and I'm sure your glad its off your hands now! Good to meet you in person as well! Look forward to having you help with my bag setup!
On the other note, I had a bit of a nightmare wiring the damn thing... I ended up using the resistor, because I dunno if our dist is a point system? I'm under the impression they are talking about the contact points for the plug wires?
I used the MSD wire diagram instead, the other one did'nt work(Dev).
I have the larger gauge cable thats black/white stripe hooked up to + on coil. The diagram from what it seems this one has to be spliced with the red wire on the blaster before the resistor?
Anyone know?
After initial warm-up, it kinda sputtered a few times before it was smooth open-throttle acceleration. I was going 60 in 3rd gear within 2 blocks I would say! Pretty impressed, and its that band-aid I needed for my weber carb!
I recommend everyone getting the MSD 5, or 5Blaster atleast!
