Electrical problem - Signals....
Z
Z
zaccutt
After finally getting my truck ready to tow to the shop I found out my right marker, left marker and lower left turn signal are not working. Nothing, just simply nothing. I check the wires where you connect them to the lights and there is no power coming through them at all. Where could there be a problem elsewhere?
Zac
slammedyota91's avatar
slammedyota91
fuse......?
Z
zaccutt
No checked all the fuses. I found the fuse that controls them by pulling them one at a time and its the one labeled 'Meter' which also controls the turnsignals on the dash and the relay clicker so it wasn't it because all of that was still working.
Zac
crazymikey's avatar
crazymikey
bad ground probably. Actually,just the other day my signals quit working on me like you described,I could flick it left or right and nothing would happen,just dead. I was like wtf? I hit my 4 ways and my 4 ways worked,so I turned em off and hit my signals again and they worked. It was kinda weird.
Follow all your wiring for the signals and check your grounds on the harnesses of the front markers and the tails. There are grounds on the frame that will probably be corroded.
nonamedsomebody's avatar
nonamedsomebody
Check your flasher under the dash on the drivers side it's up top plugged into a relay board its white. the flasher is going to be black or green in color
