Need measurement
wshb22scrpd@verizon.net's avatar
Need measurement
91&93b2600i's avatar
91&93b2600i
can some one with a b2000 or b2200 extra cab or long bed take a measurement from the end of the transmission to the pinion on the rearend. This measurement would help out a lot.
PS. Too all of you with b2600i with carrier bearing issue. I think i have a solution. but i need that measurement first before i know if itll work
mazdachick's avatar
mazdachick
we just swapped rearends a few days ago on our b2000 cuz of the carrier bearing went bad
speedster93b's avatar
speedster93b
swapped rearends cuz of a carrier bearing?
mazdachick's avatar
mazdachick
Well We Changed The Inside Gears Cuz We Werent Exactly Sure What The Noise Was And Then Painted It Yellow Lolz
91&93b2600i
well the 2600i carrier bearings are hard to find..but the 2200 are at every parts store.. the u joints are the same part number so i just wanna swap to a 2200 drive shaft and but are the lengths different.. just need a measurement.. please someone crawl under their truck with a tape measure
bagdb2200
I don't know if the lengths are different, but the input shafts for the transmissions are larger on the B2600's. At least that's what I was told, I haven't found out firsthand.
91&93b2600i
yes. you are correct about them being different sizes.. But the u-joints are the same on all b-series. which means that i can just take the part of my driveshaft that goes into the trans and put it on a 2200 driveshaft
