U-Joint
U-Joint
mazba2200
Has anyone had any problems with there rear u joint? It squeaks when i back up, annoying as hell. I think It's because of the lowering blocks, changed the angle of the driveshaft. But i looked into putting a new one in. You have to have it done at the dealership because it is a stake type U-joint. Never heard of that. Just wondering if anyone else has run into this situation. thanks guys
2lowtoy
could be the start of it going bad.
pepehn
I've changed all of my joints, I just took the Shaft out, marked it, took it to a low key transmission-rear end shop, and they did it for like 10 bucks each..Theyre definately all replacable
mazba2200
thats what i thought but, but the guy at oreillys said you can't buy them.
mazba2200
so can you just buy the u joints at any parts store. Maybe if i get the old ones out i can take them in and find them?
elbine69's avatar
elbine69
Im almost 100% sure that you cant buy the front or rear u joints. What Ive done in the past is just had the driveshaft modified so that the u joint used in the middle by the carrier bearing can be used in the whole thing because that one is replaceable.
crash's avatar
crash
the front and rears can be bought at napa. i know this for a fact. I can actually even provide the part # once I get in to work tomorrow. i had a customer that needed them and our brand (precision) doesn't show a listing. he said he got them at napa the last time and this time came back to me with the box so i could keep it for future reference.
mazba2200
I took it to Power Drive(driveline specialists) They said the front and back are stake type U-Joints. And can't be replaced like normal. So they hacked off the old yoke and put one on that you can replace the u joint in the future.
V
v8mazda4ever
I just did the ones in my friends truck and I got them at the local car quest and it was easy to change just take your time and make sure everything is really clean.
