Thoughts and Input
Thoughts and Input
oldadster
I am new to bscene and I am just looking for any input or advice on my future project. I've just been playing around with a few ideas... but have decided I want to swap in a rotary engine into my 93 b2200 single cab. Some ppl i've talked to said it'd be easier to put the truck body on an rx7... but I think i can just swap out the engine and drivetrain.
What do you think? Let me know, please and thanx.
OldAdster
hocbj23
u can put anything in a Bseries including a Cummins diesel if u have the time and $$$$.several peeps on here have already been there ,done that and I am sure can hep u out.BJ
pepehn
the 4bt? got anymore info? i know it bolts up to the th350 i think it is right?
oldadster
I am currently using it as my daily driver. I barely know much about rotary engines and setups... just researching and designing...any helpful tips are appreciated.
Right now I am trying to figure out why my back left brake light goes out when my lights are on... I think it might be the ground???
Also I have a loud squeel when my lights are on at night.... it goes away when I shift and sometimes it just cranks out a loud screech.... is it my fan belt? I bought a new belt but haven't tried putting it on yet.
Once again thanks for the info
Adster
hocbj23
If it squeals when ur lites are on it is ur alternator belt most probably.The way to check it is tp press ur finger down on the belt 1/2 way between the alternator and main drive pulley.The Belt should not deflect more than 1/4 to 1/2 inch.If it is loose,loosen the adjusting bolt and the main mounting bolt,get a tire tool or big screwdriver and put it between the block and the alternator.Apply tension until the belt is tight andwhile holding tension tighten up the top adjusting bolt and then the mounting bolt.BJ
