General Discussion \  I need help on bag set up.
General Discussion
views 601
replies 3
nascarguy3   +1y
I am working on a friends truck and need to get some help on the air system... The truck was just bought over the week and the truck has single port bags in the rear, dual ports in the front and two compressors and two tanks and 6 valves, the tanks only have 4 ports on them so do I need to run both comp. into one tank and pump it or run it one tank and one comp. and how to run the valves......
v8mazda4ever   +1y
you can seperate the system run one tank for the front and one for the rear but I would suggest running 2 more valves bro.
dropped90(justin)   +1y
i believe you can y the comps in to one port and then link the tanks together or run one comp to each tank. not a seasoned bagger though. hopefully you will get some more info.
-justin
nascarguy3   +1y
Thanks guys, I knew that I should use 2 more valves for the rear, I will work on the system and get some pics up soon...
