Mazda Projects \  My new cando control arms
Mazda Projects
views 2051
replies 8
following 5
jsnpdy22   +1y
These are new cando control arms(not kustomwerx). Made these new upper mounts today.://i113.photobucket.com/albums/n213/JsnPdy22/070323115532.
speedster93b   +1y
that's quite the minigusset! those control arms look good. do you have any up close pics of the welds?
what lower ball joint you going with? are those cups for press in bj's?
jsnpdy22   +1y
I couldnt make the gussets any bigger because of the monster crossshafts. Steve at cando said he made them huge so they wouldnt be weak at the crossshaft. The crossshaft wouldnt fit unless i notched about 1 1/2" out of the old upper mounts, so i made new ones. The lowers uses an s10 pressed in balljoint and an s10 upper also. I was very happy with the control arms
gravity5   +1y
if you were concerned about the gussets not being strong enough you could always gusset the front side as well....
jsnpdy22   +1y
Yeah, i was going to but i think it will be strong enough the way it is. Going to get my spindles tapered for the s10 balljoint, get the front bags welded in then start on the bodydrop. Maybe be able to finish the truck this year. (crossing fingers)
blue crush   +1y
I got those a arms from cando aswell.. I dont have them on my truck yet though.. Just wondering can i use my stock upper mounts or do i need to build new ones like you did??
nytrdr24   +1y
very nice....looking good, can't wait to see the finished product!
jsnpdy22   +1y
Blue crush, you can use your stock mounts you just have to cut about 1 1/2 " out of the hump on the back side on the upper mount so the crossshaft will sit flat against the mount, then replate the hole. I decided just to make new mounts. Thanks for the comment NYTRDR24.
blue crush   +1y
^^^cool thanks... very nice work by the way..
