New Slam SS Bags + MBS Discount Code!
modplant avatar
modplant
How many of you prefer Slam Specialty Bags over the competition?
All Sizes are $75 and just for being a member you can use code YSN56985 to get an additional 5% off your order!
Here are the specs for each size
SS-6 - 6" Max Diameter
Specs:
Model SS-6
Diameter 0 psi 6"
Diameter Max psi 6"
Max psi 250
Plate Material Composite
Min Height 2.7"
Max Height 11"
Mounting (Top) (2) 3/8" - 16
Mounting (Bottom) (3) 3/8" - 16
Air Port NPT (1) 1/2"
Internal Bump Stops Integrated
Force to Collapse 50lbs
Shipping Weight ea. 2.3lbs
Replaces Firestone 255 Bag, Goodyear 2B6
Features:
30% Thicker Sidwall over RE Models
Over 1" Additional Stroke over RE Models
Up to 40% Lighter than RE Models
Lightest Bag in its Class
250 psi Rating
Linear and Off-Axis Actuation
Non-Ballooning Operation
Vibration Isolation
More responsive than comparable sized Airsprings
Takes less air pressure to lift same load
SS-5 - 5" Max Diameter
Specs:
Model SS-5
Diameter 0 psi 5.5"
Diameter Max psi 5.5"
Max psi 250
Min Height 2.7"
Max Height 8.625"
Shipping Weight ea. 2.0lbs
Replaces Firestone 2500 Bag
Features:
250 psi Rating
Vibration Isolation
SS-7 - 7" Max Diameter
Specs:
Model SS-7
Diameter 0 psi 7"
Diameter Max psi 7"
Max psi 250
Min Height 2.7"
Max Height 12"
Shipping Weight ea. 3.6lbs
Replaces Firestone 224 Bag, Goodyear 2B7
Features:
250 psi Rating
Vibration Isolation
SS-8 - 8" Max Diameter
Specs:
Model SS-8
Diameter 0 psi 8"
Diameter Max psi 8"
Max psi 250
Min Height 2.7"
Max Height 13"
Force to Collapse 30lbs
Shipping Weight ea. 3.9lbs
Replaces Firestone 26 Bag, Goodyear 2B8
Features:
250 psi Rating
Vibration Isolation
v8mazda4ever avatar
v8mazda4ever
What about the He or Re models bro.
modplant avatar
modplant
We can get those for you man! They are a little more expensive though, remember you will get a 5% discount off entire order.
REs go for 85ea
HEs go for 100ea
Thanks for the post!
