Changing my entire interior....
slammedcustom@hotmail.com's avatar
kirk's avatar
kirk
Well, my project is just that, a project. The area that needs the most work, is the interior, as you shall see from the following pics. What I plan to do in the next couple of weekends, is gut my interior and return most of it to stock form. The first problem is my door panels.
These sumbitches are over 1/4" thick, do not allow for a window crank, nor an interior door release, as previously complained about in my first posting here. I like the speaker set up, but hate them otherwise. I am concerned about the damage done to the door behind the panels, but that remains to be seen.
The second problem is my seats.
I hate these things. I presume they were from an Eclipse, and were bootlegged in here. However they are mounted, they do not slide back and forth. They are also not mounted well, and rock back and forth. Will be replaced with stock seats as soon as I can find a good set. I'll recover those later.
Thirdly, the ignition surround and steering wheel are brown (covered with a ghey black cover), and my interior is grey.
Fourthly (is that a word?) my shift knob is a chrome skull with red glowing led eyes. Hmm... not a big fan.
Basically my interior is screwed, and I plan to return most of it back to stock. Seems like I'm going the wrong way, right? Maybe, but it would have to look and function better than what I have now.
Thoughts, ideas?
6
6772kevin
Looks like the person that had that before didnt have a plan at all. just kinda threw things together. Good luck and im sure it will look great when you are done.
sierrax
For your different color interior pieces, you should dye them. You can get dye from your local interior shop or online at places like . The dye is way cheaper than finding and replacing the pieces.
For your door panels theres a "how to, tech article" on making your own. Just check the site and it gives you step by step directions, materials list and tool list. Any more questions just ask.
crazymikey's avatar
crazymikey
god that looks awful! Look on the bright side....atleast you don't have to pull the dash.
V
v8mazda4ever
Ya and if you need anything for the interior hit me up I have a load of interior parts that are mint or danm close to mint that I will never use as I have copies of alot of the parts.
