lil89ram50
he completely romoved the torsion bars? ok, ive heard this done before, but it is not a good thing. not saying dont buy it for this reason, just if he did this, what else could have he done? check the frame toward the rear leaf springs for rust, i know a lot of guys have problems with frame rot. if its worth over 1500 bux bring a compression tester. do a dry and wet test on it. and make sure it hasnt been started before you got there. check coolant, and trans fluid. look for leaks, or excessive grease build up. maybe check some of the easily replaceable wear items that he could have not cared to relpace. like belts and hoses and ball joints, and maybe u joints. just another thing to see how this vehicle has been maintained. if you have a suspision at all, tell him you would like to take it on a test drive, and not just around the block either. take it on a good 50 mile test drive to check for all noises, clunks, bangs,anything out of the ordinary. smoking, over heating, blah blah blah. and post some pics of this baby
