General Discussion \  fuel sending unit
fuel sending unit
General Discussion
views 891
replies 3
neverending   +1y
ok i have a 90 ohm gm sending unit? not sure what i need to make the factory fuel guage work any help pictures... or what ohm sending unit i need... if any has wired one of these up too the factory any help would be appreciated ran out of gas in an ice storm last night not good
neverending   +1y
nobody knows what ohm sending unit to use?
89mazdawg(daniel)   +1y
i'm pretty sure you can use it, but the fuel gauge will read backwards, as in it will show empty when the tank is full.
section8   +1y
you can use it, but your guage will read empty when your tank is full. the mazda uses the same sending unit as ford which is 90-0 ohm wheras the gm one is 0-90
