Subs causing Window rattle! Please help!
6
614littleb
Any ideas on how to stop my sliding rear window from rattling when my subs hit? i have 2 mtx 12s in my single cab and get a headache from the window rattling everytime i turn it up. lol
bagged89mazda
put a solid back window in no more rattling from individual windows in rear .. IF You don't want to swap the window then only thing i can suggest other then that would be to dynomat the back wall.
MJ
mr. jaun durfle
x2 on the single piece rear window. It's easy to do and isn't as inviting for someone to break into your truck to steal your sh!t.
91b2200(cody)'s avatar
91b2200(cody)
put the little screw on window locks that go in side the truck.... those might help. i think it did with our last truck!
6
614littleb
Thanks cody, ill look into that..
6
614littleb
any link to where i could get a single window?
MJ
mr. jaun durfle
Go to your local pick-n-pull... just a flathead screwdriver is needed to take it out and some twine to put it in. The little clamp things that Cody suggested will keep the sliding window closed but won't do anything for the rattling if you have a pair of subs in your truck. Your best bet is to go get a single piece rear window.
91b2200(cody)
if its one of the middle sections rattling the clamps i showed would work. cuz i remember when i used those it kept the window tight instead of loose like some of them are. and it quit rattling in my case.
but windows are easy to get. junkyards are your friend
6
614littleb
Thanks! but twine? how does that work? lol
MJ
mr. jaun durfle
Put the twine inbetween the new window weather seal (with window in it) and the window channel, some-one presses on the window while some-one else pulls the twine to get the weather seal to seat over the window channel. Not a great explanation, but you can search it on here, that's how I figured it out. It's pretty easy trust me, once you look at it you should be able to figure it out.
