Can I put 20" wheels on 89 Mazda b2200?
dstovall1019
Can anyone tell me if I can fit 20"s on a 89 B2200? I'm sure I can but what would have to be done? I do not have a problem with cutting wheel wells out of the way but I want to know if I HAVE to move brake booster and master cylinder? The rims have super low profile tires on them already and a good deal but don't want to buy if I can't use them
CS
col. sanders
I am sure 20's will fit but you need to offer more details like your suspension setup, how low you are, wheel offset, and maybe a photo or two.
dstovall1019
275 45r 20 not sure about offset. and I just got the truck and it's been lowered what I think is 4" but no body dropped. I do intend on baggin but waiting on parts and time. Without baggin will I have to move my brake booster and master cylinder?
dstovall1019
Oh it's a 2wd
mazdadropped
you will need to cut out wheel wells , i had 4 inch block in the rear and cranked torsions and i had 18s with low pros and when i removed my torsion bar i was so lucky i cut the top out of the wheel well becuase it was about a 1/8th of a inch from the wheel well where i cut it out trust me round abouts where not fun at all , im glad i sacraficed a month of driving to start bagging it do it right , dont remove your torsion bars or crank them lower then the frame ,bad idea i dragged my torsion bar off lets just say before that the bolt for the torsion bar was ready to fall out i had her so low
splinter's avatar
splinter
you will not get that under a Mazda. thats a 30" tire, or pretty damn close.
lwrlvl's avatar
lwrlvl
Get a 225/30/20 or 245/35/20 tire will help and you need aleast a +38 to +40 offset rim.
dstovall1019
I went the safe route till I get everything to bag it then im cutting anything in the way. I just put some 17" Chevy stock wheels till im ready. It had 13" Knock-off Knock-offs on it and I couldnt drive it it was so low. I got stuck in a friends driveway once and we had to pick up the rear end and slide it over so I could leave and 1 torsion bar was off also. With the 18''s did you have to relocate your brake booster and master cylinder?
CS
col. sanders
I have 18's but I am static lowered 4in in the rear and maybe 3 in the front. One leaf removed in the rear the larger one and indexed torsions in the front, the tires are 225/45/18's. I would like to run a lower profile tire in the future and drop it a bit more then bag it. You can run a 19 in rim, to me that's the hot setup just not a common rim and tire combo compared to 20's.
hunterw's avatar
hunterw
i would def go down on the tire size. with 225/30r20s i could lay out after i gently massaged the fire wall with a hammer. lol. didnt take much. so you can lay 20s with minimal work. mine are th e ltz tahoe rims with a +31mm offset and 4x4 sheetmetal
