Page 1 of 3
General Discussion \  wheels
wheels
General Discussion
views 2752
replies 23
following 5
neverending   +1y
if i bagged on stock spindles and 2wd sheetmetal will these fit
Wheel Size 18x8"
Wheel Height 18"
Wheel Width 8"
Offset +15mm
Bolt Pattern 6x139.7mm
Back Spacing 5.09055"
Finish Chrome
bagdb2200   +1y
Short answer, nope, not at all.
mazdadropped   +1y
Lol , what backspacing,offset do i need to use to tuck 22`s on stock spindle and 2wd sheetmetal? 6 lug with 8 or 8.5" wide
neverending   +1y
what offset and backspacing for an 18x8 then
dubd dawg   +1y
your gonna want a +40 or +45mm
neverending   +1y
what about backspacing of 6.25 and a +38 offset
bagdb2200   +1y
Is that the same wheel? An 8" wheel with 6.25" BS would have an offset of +45. If the offset is +38, it would be a BS of 6".
An 8.5" wheel will be 6.25"/+38 though.
bagdb2200   +1y
You would need something with around +50 for an 8" wheel or +62-65 for a 8.5" wheel. Which you're not going to find in a 6 lug, I don't know if you can even get that high of offset with custom ordered billets in 6 lug.
neverending   +1y
so bagged would it work it is an 8.5 sorry and a diffrent wheel... 6.25 and +38
baha   +1y
Just wanted to add these links I figured these back spacing to offset, or offset to backspacing calculators could help out
Offset to backspacing
Backspacing to Offset
