General Discussion \  bag question
bag question
General Discussion
views 850
replies 6
blu   +1y
I have a 1990 cab plus b 2200 i want to bag it the back is not the problem its the front do i use the mazda front end or do i have to change to a toyota type a arm please help thanks
modplant   +1y
You just need to the torsion bag kit for the front
" target="_blank
Some people swap that front end for the i beam equipped trucks but even those don't require it.
blu   +1y
will it let me drop it on the ground or will i need drop spindles and that kit
modplant   +1y
It all depends on what size tires you want to run. If you wheel/tire combo isn't that big you can get away with out the spindles but you may need to modify the upper control arms to keep your upper ball joint from binding.
blu   +1y
i was wanting to run 20s but will settle for 18s
toddluck   +1y
20s are alot of work man
your question is kinda vague list out what you wanna do it will help
blu   +1y
i have 4x4 fenders hood and bed i want to bag it so when the air is dumped i want the frame on the ground with 18s or 20s the back i can do it is the front i dont know about
