General Discussion \  Anyone have pic of a redrilled front hub?
General Discussion
views 840
replies 2
following 2
mazdizzle   +1y
I talked to a shop last week that said they could re drill my hubs and axles to the 135mm lincoln bolt pattern for $120 all 4. I was looking at the front hubs and looks like where the rotor bolts to the back side is going to be in the way. Has anyone else done this? I know I saw a pic a while ago but can't find it now
chilnviln   +1y
are they going to fill and drill so you use the same studs or drill and tap so you have to use lug bolts?
mazdizzle   +1y
They are going to drill new holes and use new studs. The Mazda studs are 12mm and the Lincoln studs are 14. I want to use the correct lug nuts so Im buying new 14mm wheel studs. I found a pic on streetsource right after I posted this
