General Discussion \  In line fill restrictors for bags?
General Discussion
views 1651
replies 11
following 9
skrapinsask   +1y
I need to restrict my fill pressure my front and back tires actually JUMP when i air up and its a little too violent for my liking.I used some block off caps and drilled a small hole in them to restrict the amount of air that leaves the bag/line when I'm airing down because it came out way to fast with the 1/2 valves. Is there anyone restricting there fill pressure? What are you using?
Thanks guys
mazdadropped   +1y
the dump n fill control i was orginally going to use but i am going to drill out some plugs so i dont smash my body off the ground but leaving the 1/2" line the way it is incase a cop , bump , something on the road is in the way and i can air up quik
skrapinsask   +1y
yeah my dump valves are just fine with the plug+drilled hole but I'm going to need to get some restrictions for my fills because when i barely touch the switch it hops and the tires leave the ground. I'm hoping my local tractor trailer shop carries something similar so i don't have to wait for shipping.
dat dood   +1y
You could limit the pressure in the tank, or you can swap the 1/2 valves for 3/8's. Orrr, give me the 1/2's to use on my dually and just go static! j/k
skrapinsask   +1y
I'm going to have to order some of those regulators.if I limit my tank pressure I won't get to play as much!
baha   +1y
Yeah 1/2" really is over kill for a normal set up. Do you have single or dual ports?
I used smaller line closer to the bag to restrict flow into the bag. Another option is to move your valve further away from the bag. To bad you couldn't adjust your valves to control how much they open like a ball valve, or can you?
v8mazda4ever   +1y
All you need is adjustable flow controls like I put in Cids truck I can help you out with some just need to know what size line your running
skrapinsask   +1y
Hey i still really need these for half inch lines. thorbros have been sold out for a really long time! does anyone know where else i could find these? Can anyone get them for me?
thanks in advance!
trplezro   +1y
Try running less psi in the tank. Or running smaller airline. You may check a parker store to see if they have em
tucnrim   +1y
you could also get some manual ball valves to add on to each bag. then you can adjust the lift/drop rate. you could get them from any hardware/plumbing store.
