truck sputtering out
timgray6887
I have a 89 Mazda b2200 and it sputters out everytime I go up hill or get on the gas it bucks real hard. Its got gas in it just replaced the plugs wires distributor and distributor cap. I am dumb founded don't know what else to do. It works some tomes then others it wont even start.
chonged
Have you done ignition coil yet?
timgray6887
I figured it would have something to do with fuel. Maybe fuel pump filter.
bowtechkid22
check the vacuume line at the "T" from the distributor cap it made my 87 spudder bad
timgray6887
Did it stall out real bad going up hills and shut off the truck? Mine bucks really hard then shuts off and wont start up.
chonged
Well if you try to hold steady rpm in neutral about 1/4 to 1/2 throttle does it sputter. It could be vacuum advance, ignition coil or a bad vacuum on the intake. I've dealt with all these on my 86 so far.
chonged
Plus fuel pump is mechanical so when it goes it pours gas out of it. Also don't forget about the fuel filter.
Assuming it has been a while.
timgray6887
Ya it bucks really hard going up hill. That's my next move is the filter. Is it on the tank or on the firewall?
