no headlights
no headlights
neverending avatar
neverending
so i put a stock unmolested wiring harness in my truck everything works motor cranks blinkers tails everything EXCEPT THE HEADLIGHTS I HAVE NO HEADLIGHTS ANY HELP WOULD BE APPRECIATED!!!
toddluck avatar
main ground hooked head light relay good?
neverending avatar
neverending
its wierd todd the one on the passanger side is working but not the driverside.... the tails arent hooked up could that have anything to do with it? i will take any ideas on this
neverending avatar
neverending
where the hell is the headlight relay also? is that like blinker fluid
midnightmike avatar
midnightmike
umm have you checked the fuse under the hood labeled "head"?
neverending avatar
neverending
yah thats good all fuses are good....one works one doesnt
mazdawg(mikey) avatar
mazdawg(mikey)
Have you checked power at the plug?
neverending avatar
neverending
yah getting power to the plug....
neverending avatar
neverending
yah getting power to the plug hi and lo.....it is baffling me
Cusser avatar
Cusser
If you're getting power to the plug, and both filaments in the sealed beam are OK, then the third wire (the ground wire) must not be attached to good metal ground.
