Got a few question
Got a few question
mistachalk
I'm buying a four link in a few weeks and right now Im kinda lost. I need to know what to do with the gas tank and what is the formula to triangulate the link.
newbiet's avatar
newbiet
I haven't bagged mine but i've been researchin like crazy for months, for the gas tank you can pick up a fuel cell that fits between the frame in the rear and build a cradle for it or you can bolt it to the bed where there's room. Hopefully your doing a forward link setup also. You should read all the links from this thread The upper links should optimally be set at a 45 degree angle and watch the instant center throughout the cycle it should be close to the front bumper, the upper bar joints and all the joints for that matter should be parallel to the axle to help prevent binding. All the vet's can jump in and correct/add to this but this is just a little of what you should be looking for before you jump on your truck.
dropped90(justin)'s avatar
dropped90(justin)
Also a single cab gas tank will fit sideways between the rear frame rails!!!!!
-Justin
lsumazdarider
U might have to cut about a 1/2 inch out the fram but it'll fit I did mine one time like that
newbiet's avatar
newbiet
That saves me time, I put a brand new tank in and was hopin to get to use it thanks man.
dropped90(justin)
No problem man.
-Justin
