General Discussion \  having a problem i cant figure out on my b26
General Discussion
views 838
replies 4
91 b2600i   +1y
Ok I jus rebuilt the motor again, timing was dead on, had rust in tank, so I replaced tank, pump sock, filter and plugs. It runs but has a miss at idle and when I'm keeping constant speed of w.e. mph it spudders real bad loss of power. I mash the gas and runs like a champ. Now I do have my maf bolted down at an angle idk if that will affect it. My dad says timing, my friend says ignition coil and I think it might be my tps, Injectors or maybe q vac leak it something but I don't have emissions on the truck everything is capped off. I know there is a wire under dash that turns off the cel so idk any help would be nice thanks.
newbiet   +1y
Check the output voltage of the o2 sensor.
supratreo   +1y
could be many things. check for vac. leaks first. then do a leak down test and check how much blow by you have. and make sure your timing is on.
my truck was doing the same thing but i had a burnt exhaust valve.
dritydritysmazda   +1y
ya my 2.6 is doing the same thing but its carbed, not too sure what it is too
91 b2600i   +1y
I unplugged both plugs on throttle body and runs a lot better. I guess that needz to be replaced?
