Whats up guys I need some help... The other day i was driving down the road and my truck shutoff on me/ lost power and today it was hesitating while i was driving like not getting fuel idk whats going on some ppl say electrical some say fuel im not really a motor guy. All and any help would be appreciated. I do have a fuel cell with factory pump in it and its located at the back of the bed
have you checked the fuel pump relay? fuel injected? The bad thing is it could be either. Have you checked for fire at the plugs? Ifyou have good fire at the plugs that would eliminate a few things. But a weak spark could mean a bad coil or dist cap or rotor.As far as fuel pressure you would need to get a fuel pressure guage an check it.It could also be the fuel filter or maybe the filter in the fuel tank. It could also be a bad or dirty carb.
Don't overlook a faulty electrical part of the ignition switch.
yeah,definitely. today's one of those days
^^^^^^^ my 86 will loose all power once and a while . I checked everything 3 times over . One day when It happened I grabbed my key while coasting in gear and....found my problem!! lol
Yes its fuel injected and good spark recently changed y plugs havent really messed with it been busy but I did find a loose connection where lines were extended. Put a new butt connector on it and havent really had a problem yet but havent drove it enough to tell thanks for the info ill keep yall posted and ive been trying to post some pics of my truck but cant figure it out
Ok guys well my trucks falling apart lol so i was driving today and when i let off the gas the truck sounds horrible like everything in drivetrain rattling and sounds like exhaust rattling to but it also has like a clicking noise while the driveshaft is in motion only hear it when im coming to a stop.... could it be u joints or is it something more serious plz help this is my daily driver thanks
Ok guys I figured it out it was the u joint it was pretty much bout to fall out
A u-joint made your engine stall?
No... Ive had 2 dif problems idk if u read the whole post
