General Discussion \  Body lift
Body lift
General Discussion
views 1373
replies 7
following 5
thsmith   +1y
Anyone ever do a body lift for there mazda or ranger? I can't figure out if I do a 2" if I would need new steering linkage and brake lines and stuff
87_b2600   +1y
It would prob need new lines, u will have to add to the steering linkage u will also have to add to your shifter controls. To me its a waste of time doing all that when u can just lift the torsion bars and put blocks in the back
thsmith   +1y
Problem is my torsion are tightened all the way and the truck is barely level so adding blocks in the back would give a tilt
topless   +1y
Reindex the bars! Works for lowering go the other way ! Should raise it some ! ? I would think!
89mazdalade   +1y
what are u tryin to achieve??? i got 24's on my 86 b2000 i was thinkin about a body lift but i think they look terrible i cranked my torsion bars up maxed out the suspension on the bump stops so i cut them out put heavy duty 4x4 shocks on the front and back front shocks are for a 90s bronco rears are stock mazda 4x4s i also had to cut my upper a-arms and extend them 1/2 inch because my wheels where pulled in do to raisin the front suspension
thsmith   +1y
I just want a body lift cause there cheap and i want to slap 35's on it, but i dont want to have to buy extensions for brake lines and things like that
89mazdalade   +1y
ur definitely gonna have to get extended brake lines as far as the steering u"ll be good for a 2 inch body lift i was reading alot on mazda truckin for the body lifts for these trucks
pantharen   +1y
Body/suspension lifts look dumb on a 2WD truck.. If you want to lift it, then buy a 4x4..
