gears
gears
thsmith
anyone tell me what the science behind lowering your gears for bigger tires is?
danny91b2200
actualy theres no science to it Whenever larger-than-stock tires are installed on a truck, it will have a direct effect on the truck's performance. Why? It has to do with the effective gear ratio. Your truck comes from the factory with the optimum axle gear ratio to work with the truck's engine, transmission, and stock tire combination as well as provide a good balance between acceleration and fuel economy. When taller tires are installed on a truck but the axle ratios stay the same; the effective gear ratio is reduced. This means the engine is forced to operate below its power band, and performance and fuel economy suffer as a result. In order to restore the effective gear ratio (and the truck's performance), you'll need to have the axle gears swapped to lower (numerically higher) ratios. hope that help....
