General Discussion \  Rear End
Rear End
General Discussion
views 950
replies 4
rawdawg503   +1y
so i have a b2200 with a small block 350 with a turbo 350 but it has the stock 5 speed rear end and when in drive doing approxametely 60 mph its reving at almost 4000 rmps. My question is if i were to put a rear end out of a 2200 with an automatic would it help with my over reving problem?
baha   +1y
I don't think that would fix your issue, I believe the gear ratios are the same. It could be your transmission. Does it have overdrive?
sincitylocal   +1y
The automatic and standard rear are the same ratio.
You're going to have to upgrade your transmission to a 200-4r or a 700r4, to take advantage of an overdrive.
You might also consider swapping a GM 10 bolt, for gear availability, because there is little to nothing available for the Mazda rear.
Not to mention, the Mazda rear will die behind a 350... I have killed three of them!
oo7bob   +1y
Both rears have the same 3.90 to 1 ratio.
An overdrive trans will bring those rpm's down if your willing to spend about a $1000.
The easier way to bring down the rpm's is by using taller tires.
What size tire you running on the back?
rawdawg503   +1y
Thanks to: baha, sincitylocal, and oo7bob!!! You gave the exact information that i was needing. I had already known about the overdrive with the 700r4 and with me handicapped be best idea. Was just hoping the standard trannsmission rear end would be a different gear ratio then the automatic.....But now i know. Thanks again fellas
Happy Truckin.
