whats up guys so im wondering whats the easiest way to connect the tranny to motor... should i pull the trsnny from under truck and connect to motor then drop it or should i just drop the motor in then connect tranny or is there any other easy ways to go about doin this thanks in advance
If the transmission is in the truck and the engine is out, just drop the engine in and bolt it up.
Pulling the trans out is just more work.
Not to mention how difficult it can be to fit the engine/trans combo in at the extreme angle you'll need to get the job done... leaking transmission fluid all over the ground
got ya i was gonna pull the trans out and clean it and paint it but its actually not that dirty thanks guys
