Annoying clunkin when i shift
I
isaacsmiley
So theres this really annoying and loud clunking noise whenever i shift, or accelerate. I thought it was the exhaust but its not i was thinking maybe its a bad seal on the crank. ANY IDEAS?
mazdafvr
check your drive shaft. make sure its not loose or if u have a carrier bearing, make sure its not letting the shaft sag or move around too much. that would be the easiest place to start.
fdugn545's avatar
fdugn545
Agreed I had this very issue and thought it was tranny or exhaust turned out to be u joint next to carrier bearing... check it out though if it is get it changed...mine broke Loose coming home one day and I only had one of the like caps holding my driveshaft in! Learn from my mistakes...
Sent from GS2 on Tapatalk
berryserious
+1 carrier bearing
87forever's avatar
87forever
Worst case scenerio might be your rear end ring and pinion.I would def check your drive line up on jacks (rear axle off ground) in neutral for slop and go from there.A good check of the u joints and carrier.Now if you have a standard cab,no carrier bearing but,check the above.Seems here in the last wk two other members have had issues with noise with the same or similar issues.Standard or cabplus you can turn the axle on jacks and feel the clump if a bad or worn u joint or carrier or r/p depending on your trucks model.Out of go power and tired so just sharing and yeah been thru the same or similar problems.
I
isaacsmiley
Thanks, my truck is single cab 1989 mazda b2200. So ill look and see whats wrong.
jenko
First thoughts are the UJ like the others.
Also check your engine/gearbox mounts.
"Clunks" are usually mechanical, "taps" can be exhaust related, lol
DB
dizzy baird
carrier bearing definitely possible u joints as well. mine was doing this and i went to napa and bought the whole boot and carrier bearing. no more bang lol
I
isaacsmiley
I changed out the carrier bearing and ujoint now it's working fine.
