Suppliers of parts, and a few tips needed.
1 following
kam
Hello all.
I'm on a budget here mind you, not too tight of one, but a rather tight one compared to the lot of the modders I see here.
But anyway, without further ado, I am looking for a couple of parts, and was wondering if any of you knew of the best bang for my buck for these components.
The truck in question is a B2600I
1- I want purple tinted taillights. No need to be fancy, just purple. (when sitting, not during driving of course)
2- I need all the little rubber parts for my suspension. Bushings that Is. Preferably (if available) in a single kit.
3- A nice steering wheel that will bolt right on. If I can't go below 100, I won't do it
4- A supercharger kit, somewhere between 75 and 150 dollars.
5-Just kidding on #4
6- a higher end air filter, just for a mostly-stock system. Not looking to do much, besides improve the noise a bit.
7- see the next part.
As for some things I want to do,
1- I would like to lower the truck a bit, just with the suspension. On that note, I want to use as much of the stock suspension as possible, all if possible.
Mind you, I'm not looking to go way way way low here. This truck is still primarily my... go to work, and do work vehicle. That being said, if there is a reasonably easy, and reasonably cheap way to drop an inch or two safely, lets hear it.
2- I want to do dual exhaust pipes. That being said, unless anybody else has any ideas, I am just going to chop the exhaust manifold in half and weld. (no cat. on this one, so its all good)
3- I am considering going for some sort of cold air intake/scoop system. Perhaps not, but we shall see.
^_^
_KAM_
