Overspray remedies?
fred554692@gmail.com's avatar
Overspray remedies?
fdugn545's avatar
fdugn545
Okay so I was cleaning my eskies the other day and noticed a small area of black flecks/dots on them and freaked out. I'm guessing there was a slight gap in the masking when I was doing some bodywork a few months ago... Any ideas on how to safely remove it? It's not very noticeable but I know it's there so it disgusts/bugs me all the time!!!
Thanks as always,
Fred
Sent from Samsung Galaxy S3 using Tapatalk 2
mymmeryloss's avatar
mymmeryloss
Quick drying thinner or steel wool
fdugn545's avatar
fdugn545
Will either of those harm the chrome? I don't want any blemishes on my eskies!
dan woodland's avatar
dan woodland
Full strength Simple Green, no it won't hurt your wheels. Soak a rag and hold it against it for a minute or two, it should soften it enough to allow you to wipe it off.
If Dan's remedy doesn't work you could also try a clay bar like Mothers. It's been over 10 years since I worked at a body shop but we had something similar we used to remove over spray.
fdugn545's avatar
fdugn545
Allright guys thank you all for the advice! I'll let you know what does the trick.
kovz's avatar
kovz
I was going to say the same about claybar. That should do the trick, but the simple green is cheaper (if that works).
