Engine died
3kuglers@gmail.com's avatar
Engine died
mazdaron's avatar
mazdaron
I have a 86 B2000 w/a 2200 motor. Yesterday after 30 miles I stopped at a light and it slowly died. I was thinking it was the coil because its one of the only things from the ignition I've never changed. The strange thing is I put a test light on the coil and I had power going to the negative and positive leads. I changed the coil for the hell of it and same thing no start. I pilled the fuel filter and tried to start and no fuel came out of the line, but then again isn't it a mechanical fuel pump under the carb? Btw its a 5 speed
jackedupb2200's avatar
jackedupb2200
Sounds like the same problem in having with mine, check out the distributor, specifically the ignition reluctor, i play with that and it gets mine ruining again
Hope this helps let me know if it does
