General Discussion \  b2600i rear c notch size
General Discussion
views 1525
replies 4
following 2
hib2600i   +1y
Im new to this site from hawaii so if anyone could shread some light on my topic that would be much appreciated but i have a 93 b2600i ex cab static dropped on stock rim & tires my problem right now is that my frame is sitting on axle so there is no axle clearence. im ready to step notch the rear but was wondering how do i measure what size c notch do i need?????? I measured from under the cab to the ground its 4" thats all i got after that i was kinda lost.
lowlyfe   +1y
Well it sounds like you will need a full step notch if your frame is resting on the axle. You can buy a mazda specific notch from guiltybydesign on here... It may be a little big if your not going to bag the truck though. Otherwise you can trim a generic notch kit to fit your trucks needs, id just measure bottom of the frame to the ground and then notch it somewhere close to that number to give the suspension the room it needs to clear the frame
hib2600i   +1y
Yeah thanks man for some advice. i was thinking da b2200 frame is wat 2x3 or 2x4 so my frame is sitting on axle right now i was gonna do a 7" c notch from the bottom of the frame, so my axle moved up 2-3 from under the frame to were the frame was so that leaves me wit an 1" or little more ground clearence an 3-4" clearence on top of axle for tilting going around turns!! What u think alittle to much or that should be good????
hib2600i   +1y
Oh yeah i have 4" angled blocks in the back but will be going to 5" before i do the step notch!!!!
lowlyfe   +1y
You can go with as large of a notch as you want to, but it sounds like in your case just order the mazda specific notch but you will probably have to cut into the bed floor to clear it.
